跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
earpiece not working but loudspeaker or earbuds do
iPhone 4- Headphones or earbuds still work when plugged in. Loudspeaker at base works if speakerphone chosen. Earpiece has suddenly stopped working. Had been using headphones just prior. Is this a function of the headphone jack not releasing the sound circuit back to the earpiece or the earpiece itself just died? So do I need a headphone jack assembly or just an earpiece speaker?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
my@iphone 6+ ear piece side is not working but d speaker does pls what can i do
完成的
添加一条评论
11个答案
最有帮助的答案
Disclaimer! If my troubleshooting steps make the device worst then it already is, I am not...i repeat, I will not be responsible for it. So use these steps at your OWN RISK!:
I work as advance tech special for a wireless company. What normally work for that specific device is:
1) Plug a headphone into the device
2) Make a test call and make sure you are able to ear call on headphone
3) Toggle the Speaker on & off and make sure you are able to hear call on the headphone
4) Toggle Speaker OFF
5) Remove headphone
6) You should be able to hear from earpiece now.
7) If all fails - Restore via iTunes!
By: The Subliminal Poet (follow me on twitter, fb, and instagram)
这个答案有帮助吗?
得分 8
6条评论:
This worked perfectly first time I tried it. Phone is doing it again but cure doesn't seem to be working :(
完成的
Just saved me a trip to Apple! Thank you!!
完成的
Awesome !!! its worked perfectly...now its working... thank you!!!!
完成的
Worked for me. Thanks
Len D
完成的
Great!!! Worked for iPhone 6s plus. Thank You!
完成的
显示更多的1条评论
添加一条评论
Usually that would be only the earpiece, that's where I would start, a link to the part, https://www.gounlock.com/details.php?ite..., a guide, iPhone 4 Earpiece Speaker Replacement, good luck, If this Answer is helpful please remember to return and mark it Accepted
这个答案有帮助吗?
得分 1
2条评论:
Well, it was not the earpiece. Ordered one but through trial and error determined that by holding the phone upside-down and re-inserting the headphone jack several times I could get the earpiece to work again eventually. As long as I didn't use the headphones or earbuds the earpiece worked for days. It always failed right after the headphones were unplugged. Ordered the headphone jack and volume control cable and tore the whole thing apart to replace it. Seems to be working fine now.... certainly don't want to do that again anytime soon!!
Since I had the phone apart I replaced my funky Dock Connector too.
Rick
完成的
When absolutely none of this worked for me I took a screwdriver and whacked the !&&* out of the top of my phone. NOW IT WORKS! Probably will not work for most people though. Of course I already reset my phone losing my settings and my purchased ringtones forever. I HATE Apple!
完成的
添加一条评论
Koo.. It worked for me..
这个答案有帮助吗?
得分 1
添加一条评论
This worked for me ..... Your awesome dude!
这个答案有帮助吗?
得分 0
添加一条评论
This worked for me. Thank you so much!!
这个答案有帮助吗?
得分 0
添加一条评论
Thankyou sooooooooooo much!
I tried all the other solutions i found online, compressed air into the headphone socket, pushing the jack in and out, squeezing the speaker face and even a restore.
I was pretty much ready to start crying when i found this!
Thanks again you wonderful genius! :D
这个答案有帮助吗?
得分 0
1条评论:
Ok so my outter speaker works perfectly fine, but the ear piece speaker doesn't work properly, it fries and make baffling sounds, when I make and receive calls I have changed my speaker, I have updated to 8.1.1, also restore my phone. But it works perfectly fine when I use viber and Magic jack, or even Facebook messenger so what's the problem??
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
Try switching to Android... That's always worked for me.. Just saying, lol.
vviii
这个答案有帮助吗?
得分 0
添加一条评论
First restart your device, then blow the headphone jack and plug your headphone, listen to something first , than unplug it, and test it out
这个答案有帮助吗?
得分 0
添加一条评论
dear sir i cant hear sound during call but hear sound when i on the speaker kindly help me about this problem
这个答案有帮助吗?
得分 0
添加一条评论
My phone earpiece not working I don't know why
这个答案有帮助吗?
得分 0
1条评论:
One this should be another question, and 2 did you even read anything in this post?
完成的
添加一条评论
添加你的答案
ramosel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 85,677
