跳转到主内容
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 个问题 查看全部
I want to max-out the RAM on my ACER
I want to max out the RAM on this machine, the specification says the following:
RAM / Max RAM
512 MB onboard DDR2 533 MHz SDRAM single channel with onboard SDRAM and one soDIMM slot, with up to 1 GB/1.5 GB using one 512 MB/1 GB soDIMM module
The machine when I check my PC general says it has 0.98GB.
My question is what do I need to buy from you in order to maximize the RAM on my Acer ZG5?
Regards,
GraemeD
GDonald386@aol.com
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You can put a 1 GB stick which can be bought here or here
Not that it will display a little less than 1.5 Gb when installed, this is due to the fact that a part of the RAM is used for VRAM.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
GDonald386 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,309
