跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Screen lights up but no picture, phone works but screen is black
Had a broken home button which I've just replaced today but after reassembly the phone appears to be dead when power button is pressed.
It will eventually start and the screen goes from being completely black to a lit up black when home or the power button is pressed, its recognized by iTunes and will sync so all seems to be working fine except the screen.
any ideas what the problem may be?
or have I broken the screen accidentally during repair
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
try holding the power and home button for 10 seconds to force your phone to restart. if that doesn't fix it then open the phone up again and check under the wifi antenna and make sure the data cable for the display is securely pressed down. if it is then you damaged the display and need to replace it.
这个答案有帮助吗?
得分 3
1条评论:
Tried holding home and power, still no difference, will fully take apart and reassemble again and see if I have any luck.
Thanks for the reply
完成的
添加一条评论
Sorry to be the one with the bad news Zeruel but your going to need a new front screen assembly, you either flexed your LCD while prying it from the mid frame and damaged it or damaged your LCD-Digitizer ribbon cables assembling it, its real easy to do, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
Mitch: I’m having the same issue, despite getting a new screen. Is it possible the screen is faulty/I damaged it during installation? Or could it be the connection point with the rest of the phone?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zeruel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 73
总计 32,313
