跳转到主内容
12.5mm Hard Drive Fitting
Will a 12.5mm hard drive fit in a Late 2009 MacBook Pro 13 inch?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
Hi, A check of the drives listed for this unit are all 9.5 and I can find nothing on my other sources to indicate the larger drive would fit. Is the 12.5 you are thinking about a SATA drive? Thats what you computer requires. Good luck in your search. Ralph
http://www.ifixit.com/Mac-Parts/MacBook-...
这个答案有帮助吗?
得分 2
6条评论:
I am looking for a SATA drive, but a 1tb.
完成的
OK These people have a 1TB SATA drive for a laptop. Ralph
http://eshop.macsales.com/shop/hard-driv...
完成的
But will they fit my mac with no problems?
完成的
I would think so the way they are advertised. Sales people there are very knowledgeable and they include a toll free number so you can call with your particulars for their advice. They stand behind their products and are a company I for one use frequently for Mac parts. Ralph
完成的
完成的
显示更多的1条评论
添加一条评论
No, the 12.5mm will not fit unless you take out all of the mounting hardware and jam the harddrive in (not recommended) So far, the only Apple that takes the 12.5mm drives are the older 17" MacBook Pro Aluminums (not Unibody). This applies to the 750Gb and 1Tb drives now available.
这个答案有帮助吗?
得分 1
添加一条评论
I have just installed a 1TB Toshiba 12.5mm drive in my new MacBook Pro 13".
It fits perfectly, the MBP is clearly designed to accomodate a 12.5mm drive.
Kurt
这个答案有帮助吗?
得分 0
1条评论:
Thnaks
完成的
添加一条评论
I've seen conflicting reports about the unibody MBPs... for those successful at using a 12.5 mm drive, do you have the old core 2 duo or the new i5/i7 line?
这个答案有帮助吗?
得分 0
1条评论:
Core 2 Dou version
完成的
添加一条评论
添加你的答案
Angelica Pullins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 7,091
