跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
121 个问题 查看全部
PowerBook G4 ribbon cable locking clip
I disassembled my PowerBook G4 and put it back together. Now it doesn't power on at all. The only thing I can think of is that when I was assembling it, I broke a leg off of the small locking clip that connect the keyboard/power ribbon cable to the board. I'm thinking it's not applying enough pressure to make contact. Where can I find this small piece? The top red arrow in the photo shows the piece I need.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
I don't think that's repairable. What you can try is to make a good connection and tape the cable to keep it from working loose. If you are careful you should be able to use some of the yellow tape Apple uses in the computer. Here's a URL to a previous problem solved with tape. Ralph
replace yellow tape inside laptop with..?..
这个答案有帮助吗?
得分 3
添加一条评论
I used a piece of transparency. I cut it into 3 thin strips, taped them together then slid it under the ribbon cable. It's important to know that the connection is at the top of the cable, rather than under. Once it is connected and working, secure the transparency (or other type of thin plastic) to the ribbon cable...good luck!
这个答案有帮助吗?
得分 1
1条评论:
+Good use of alternate materials
完成的
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 3,345
