Oil leak near timing chain
Have and oil leak near oil pan and harmonic balancer in my 2007 unlimited sahara edition wrangler
Could be the oil pan gasket. Spray it off with some engine cleaner and investigate where it leaks from. take a couple of pictures and post those on here.There is also the oil pump that is in the front cover, driven from the front of the crankshaft. Oil passes in and out of the front cover through the timing cover gaskets which may have failed. A failed front crank seal will usually fling oil off the damper and soak the area.
这个答案有帮助吗?
Oil consum engine 08 wrangler
这个答案有帮助吗?
Sergo Saintil, I suppose you mean to ask a question:-) What exactly do you want to find out about?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,998
2条评论
what engine is it,4.0?
由 oldturkey03 完成的
3.8 v-6 engine
由 Miguel Guebara 完成的
