How to increase RAM in Sony Vaio Duo 11
Hi
Is it possible to increase RAM In Sony Vaio Duo 11 from 8 GB to 12 GB?
Thx,
Alan
If you look at the pictures in the review at Notebookcheck.net, it looks like the RAM is soldered on, so no easy replacement.
这个答案有帮助吗?
two of the spaces are used up with the preinstalled RAM sticks which i presume are 4gb each on the 8gb model because majority of computers have 4 stick spots. this leaves two empty ram spots, unless of course the vaio model only has two spots, where in this case they should be removed and have stronger sticks put in. But remember this is not a super computer built with different parts by a pro, this is a legal strengthed computer, if u jack it up with 4 separate 32RAM sticks then it will be 128 gigs of ram but it will be unstable like a bimbo on the mechanical bull. no matter how much you pimp out a crappy car with engines and parts its still a crappy car, unless buildingcomputers from scratch is your thing you should find a different hobby, btw if you want nice computer parts then buy from newegg.com its where i get a lot of my stuff
这个答案有帮助吗?
It depends how many slots you have and up to much it support which you check by going through your laptop`s specifications. Check it you have two slots then you may need to order one 4Gb and other 8Gb module then carefully replace them by opening the Ram section.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 10,320
