跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
227 个问题 查看全部
Won't do anything. Basically bricked...? Ideas?
This thing was never dropped. I had it in my car during the winter, and it is in good shape. When I brought it inside, it won't take a charge, the screen doesn't show any symbols at all. I plugged headphones into it, and pushed the play button, thinking maybe the screen wasn't working. Nothing.
I followed the instructions to open it up, and I carefully disconnected the battery, and re-connected it. I also disconnected the HD, and re-connected that as well. Put it back together, and nothing. It also does nothing when connected to my MacBook.
Anybody got ideas? Other than the trash can?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would recommend replacing the battery as well as the logic board. If the problem was merely the battery, you would still be able to power the iPod while plugged into the wall. Since the logic board controls the functionality of the iPod, you need to replace that to get up and running. Replacing the battery is a relatively inexpensive thing to do while you are replacing the logic board. If the battery inside is the original factory battery, chances are it is not in that great of shape.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bigakinkade 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,523
