跳转到主内容
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
308 个问题 查看全部
Squealing when it is turned on.
Model # 11097892601 With the model number can you tell us where we need to find the roller to replace?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
your dryer should also have the repair information that you are seeking in the tech sheet that is normally behind the bottom front service panel of the dryer.
完成的
添加一条评论
2个答案
已选择的解决方案
Sounds to me like the belt.
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
http://www.repairclinic.com/Kenmore-Drye...
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
==OOPS==
Sorry mayer for messing with your answer. Just wanted to place the page from the manual to help out.
oldturkey03
这个答案有帮助吗?
得分 2
添加一条评论
While you are in there, replace the roller wheels AND the belt. you'll be glad you did later on.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ruth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 35
过去 30 天: 199
总计 28,463
