跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
531 个问题 查看全部
Need LCD inverter for A1297
I need a new LCD power inverter for my A1297 but I can't seem to find one for sale or a part number. Could someone provide me with the part number or where I can purchase it?
thanks!
Art Green
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
Your machine doesn't have an inverter. What seems to be your problem? Have you tried hooking up to an external monitor to try to isolate the issue?
这个答案有帮助吗?
按维修分数 2
评论:
Mayer, bless you for answering! I was getting so frustrated.
So, this is a water damage issue. A small amount of water entered the rear of the unit next to the power port. After taking action, the display was dark but the unit booted. Attached external monitor and it works. I inspected video cable and noticed that there was some discoloration on the connectors. I gently cleaned and reconnected to the logic board. Still no backlight. However, if I shine a bright light through the translucent Apple logo, I can faintly see an image matching that of the external display.
That's as far as I've been able to repair/troubleshoot. I assumed that there would be an inverter for the LCD but, thanks to you, that's not a possible problem.
ANY advice would be appreciated.
Art
Water damage creates such varied problems that it's hard for an individual to repair them. If it were me I'd just hook up a spare LED. To save time and money you might call a local tech and see if they have a test screen.
添加一条评论
添加你的答案
Art 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 929
