跳转到主内容
The Asus Zenbook UX31A is a laptop released in June of 2012. It is a member of Asus's Ultrabook line. It features a 3rd generation Intel Core I7 processor and a full HD IPS Display.
36 个问题 查看全部
Volume buttons fn f11 won't work (asus zenbook ux31a)
So I have been researching everywhere and I did come upon the ifixit link with the step-by-step guide on how to "lock in the connector." However, even after doing that and taping it down with better tape, my volume button STILL does not work. Anybody else experience this? If so, what did you do to resolve the issue? The same works for when I try "fn" + f10/f11/f12 and I often get a delayed response for the "fn" + f5/f6.
Help please? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
I have a similar issue. When I hit F12 (the volume control) in an open browser, I get a window at the bottom that shows the page code. None of the volume control buttons work, and only some of the other function-buttons seems to have any affect. I'd love an answer to this. You don't pay $1500 for a computer that doesn't work. This is why people buy Macs. And why I'm starting to wish I did.
完成的
YES! that happens to me too and the F10 won't work either. Is there any way to fix this?
完成的
you have to press Fn key (left bottom of keyboard) and at the same time top keys whichever you want F5, F6 for brightness or F11 or F12 for audio volume down and up, respectivelhy
完成的
Thank you for that! That's easy :)
完成的
Is there a way to change it so you don't have to use the fn key to press those buttons?
完成的
显示更多的1条评论
添加一条评论
3个答案
已选择的解决方案
You should check to confirm that the ATKACPI driver is installed along with any other hotkey utilities. The Asus support website has downloads for these items depending on your operating system. Here is the url: http://support.asus.com/download.aspx?SL...
At the top of the Downloads tab there is a drop-down to select your OS. The download you need is located in Utilities and it called; ATKACPI driver and hotkey-related utilities.
I hope this helps!
-TV
这个答案有帮助吗?
得分 8
7条评论:
oh my goodness it worked. thank you so so so much!!!!
完成的
I would like to say YOU ARE AWESOME! IT WORKSSSSSSSS
完成的
Really appreciate your help, thanks a lot bud!
完成的
I have the same problem. But the file you recommend was allready installed on my computer. The problem remains. Any alternative solutions?
完成的
It works! Very helpful! THANKS A LOT!
完成的
显示更多的2条评论
添加一条评论
I've just started having this problem as well.
Function works with
f1, f5, f6, f7
Function DOES NOT work with
f2, f3, f4, f8, f9, f10, f11, f12
also my scrolling on the touch screen is intermittent, and my arrow keys don't always work. The laptop is 18 months old...
这个答案有帮助吗?
得分 0
1条评论:
Have exactly the same problem with Asus K53SV...How did you solve the problem?
完成的
添加一条评论
todd thank you ! this worked !!! Great.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daphne 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 31
总计 47,750
