跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
No Career Name after battery replacement
I just tried to replace my battery on my iphone 4. I got through it pretty easily. But then When I go to turn my phone on, I see no carrier name (i do have my iphone factory unlocked for tmobile, but I don't think that that should make a difference). So I send a text and it goes through, (but at a slow speed), and when I try a call, the phone I am calling rings, they answer, and my phone just says "calling" still! I also don't hear a ring through my ear piece.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
See if your old battery makes it act normal, if it does you should buy a different new one from a good source, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
After Mitch advice, if there is still problems. Try reset network, tap Settings App > General > Reset > Reset Network Settings. If still problem make sure antenna flex is connected correctly. If still problem restore iPhone with iTunes on computer.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Chandler Young 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 292
