跳转到主内容
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 个问题 查看全部
"Contol locked" light is on. Nothing else responds.
The "control locked" red light is on and the dryer will not respond when any other button is pushed. What to do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 22
19条评论
Thank you for the Control Lock reset fix! Worked great and saved me possibly a few hundred dollars on repairs! :)
完成的
I have a Whirlpool Duet and I had to hold the End of Cycle button for about 3 seconds. Thanks!
完成的
If lock light wont go off,wont reset,You Can Wash dishes! Just drive a finishing nail into lock light til it goes out. I swear you will have full wash powers, just won't lock.But, I Never knew it had a lock till it stuck. I did this,as instructed by appliance serviceman of 40yrs. It works perfectly fine and no $ outta my wallet. This is a 20 yr old washer, not saying do it on newer model Kenmore D/W.
完成的
I tried everything else.. I literally smashed a finishing nail into the light and my piece of crap Kenmore dishwasher came to life instantly.
Totally incredible. Thanks Rusty.. Awesome advice!!
I'm tearing down my house in 4-6 months and I did not want to install a new dishwasher, so this certainly got the job done!! :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
完成的
Worked for me. I did it with the power off and removed the finishing nail. I cannot understand how this could work. Lets see how long it lasts!!!!!!!!!!!
完成的
显示更多的14条评论
添加一条评论
9个答案
已选择的解决方案
Deborah, try this first:"
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
这个答案有帮助吗?
得分 40
52条评论:
thank you, saved me a ton i was about to call a repair guy, and of course the machine says exactly what to do on it!!!
完成的
OMG! Thanks! I was not looking forward o calling Sears tomorrow! You Rock!
完成的
I tried that many times it's printed right near the button
Still won't start
完成的
Yeap it works! Thanks
完成的
it worked!!!! I can cancel the dryer appt!!! THANK YOU!!
完成的
显示更多的47条评论
添加一条评论
In addition to Oldturkeys answer, try unplugging it for five minutes to allow it to reset.
这个答案有帮助吗?
得分 5
13条评论:
I unplugged when all else failed still didn't work
完成的
I'm gonna try that now
完成的
It didn't work
完成的
I worked in the hospital for 30 years. Anytime you call biomed with a problem that was the first thing they told you to do. Thank you!
完成的
Tryed that too dont work...there is no control lock button
完成的
显示更多的8条评论
添加一条评论
I have the HE4. I tried all of this, and they didn't work. However, I pressed and held the "Auto Dry Level" just to test other things, and it did the trick for me. Appreciate the input because I wouldn't have tried it otherwise though.
这个答案有帮助吗?
得分 4
4条评论:
Thanks for that information..it worked! :)
完成的
I was in the WTH portion of fixing and this worked!!
完成的
I pressed "end cycle" and it did the trick
完成的
I held the Auto dry level after trying the press and hold, that was great advice thank you so much
完成的
添加一条评论
Turn off the power to the dryer for about a minute then turn it back on.
If the control lock is still on then push the “End of Cycle Signal” button for 3 seconds.
If it still won’t respond then you need a new control board!
这个答案有帮助吗?
得分 4
3条评论:
I actually had to do as you suggested but the second time it corrected the problem. Thank you. I’m glad I did not need a new control board.
完成的
THANK YOU - truly appreciate your help and you saved me a ton of $$$
完成的
Thank you for the information. Occasionally the information super highway actually informs.
完成的
添加一条评论
I have a Kenmore Elite he3 and I have to hold the "Drain/Spin" button "AND" the main "Start (Press & Hold)" button at the same time for 3 seconds. Works every time.
这个答案有帮助吗?
得分 2
4条评论:
Seriously you just saved my life!
完成的
Thanks!!!!!!!!!!
完成的
I held the start button and control Lock button at the same time for for a few seconds until you hear the beep sounds and a unlock sound.
完成的
This worked for me as well! Thank you!
完成的
添加一条评论
If your control panel looks like this, I pushed and held each button for 10 seconds starting with the top left and working to my right bottom. On mine it was the ‘End of Cycle Signal” button. How I did this was, to first unplug it for 5 min (didn’t work) Then, push a single button at 1 time for 10 seconds and hit the pink cancel button 1 time between each new button. until it works or if it hadn’t , My plan was to begin pushing 2 at a time in a logical order. It won’t let me post the pictures, sorry.
这个答案有帮助吗?
得分 2
3条评论:
It was the End of cycle signal button for me also. Thanks for posting.
完成的
I also pressed the pink control button and the end of cycle button at the same time for 10 seconds and it worked.
完成的
Holding the end of the cycle button for three seconds did the trick . Afterwards I noticed that directions printed right below the end of the cycle. Geez!
完成的
添加一条评论
I held the auto steam button for 3 seconds and it worked
这个答案有帮助吗?
得分 0
添加一条评论
Whirlpool duet, didn't work for me. Somtimes if I unplug, wait and replug, it goes off. Other times it does not. But I don't even think the door locks. Please help, so annoying with half dried clothes.
这个答案有帮助吗?
得分 0
1条评论:
Pushing button for 3 seconds worked for me. It is time to clean the lint from the back of it. This should be done regularly. I would say at least 4 times a year.
完成的
添加一条评论
Did not work for me.
这个答案有帮助吗?
得分 0
1条评论:
OMG! You are a life saver! Thank you God bless you! I thought I was going to have to call a repairman!
完成的
添加一条评论
添加你的答案
Deborah 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 64
过去 30 天: 333
总计 161,844
