break line how to fix
How much would it cost to fix a break line?
tarra, depends on which line. If you are talking about the steel lines from your master cylinder to the wheels, you are looking around $100 and to replace all lines I would calculate between 4 to 8 hrs labor. Depends on if they remove the old lines and use the same mounts or leave the old and just place the new ones besides. So, between $300 to $600 for labor cost. Of course, this is for all the lines, since you did not state which line you need to replace. Hope this helps, good luck
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 303
