跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2520 个问题 查看全部
iPhone 5 Vibrator Make Noise?
The vibrator on my iPhone makes a strange rattle after it vibrates. Like right after it finishes vibrating, I hear a slight rattle. It's super annoying when I'm on a call and I get a text, it's very noticeable at that time.
Its normal ?
Or
Should I replace my vibrator?
Please help me
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The I 5 went back to a spinning type vibrator, so there is a moving part, I would say there is a loose or missing screw that secures it to the frame or there is something rubbing against it causing the sound, if its not under warranty it's easy to access the vibrator and find out whats going on and fix it, also the vibrator may need to be replaced although I rarely see them go bad, iPhone 5 Vibrator Replacement good luck, keep me posted.
这个答案有帮助吗?
得分 0
1条评论:
Thank you very much, but I'm scared to open phone and repair it ؛-(
完成的
添加一条评论
添加你的答案
Msgoldasteh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,406
