跳转到主内容
HP Color LaserJet CP1215 is a single-function laser printer marketed for small businesses and home offices.
12 个问题 查看全部
问题已关闭
faded green color on printouts photo & texts
faded green color on printouts both photo &texts yet blue and yellow cartridges are new original hp toners.Like when i printout the self test page the green color on the microsoft logo does not appear rich green as on my comp. screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Apparently seems like your drum`s specific ink level is low. You can try by taking out your drum and putting it back after carefully cleaning it. If not then you may need to check with your printer support or you may have to change your drum.
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题
Most likely its a faulty toner... The focus would be on the Yellow or Cyan toner. Access the control panel on this printer by going to print menu to print "color self test page" when printed this should show you the faulty toner by its off color appearance on the printout.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 521
