跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
Stuck clambshell release button/latch
To open my PB 17" I have to slide a business card between the monitor and case then slide it gently left and right to release the latches that hold the monitor closed, at which point the monitor opens as normal.
When closing the monitor all works as normal.
When pressing the front release button nothing happens.
The release button does have some play in it.
Is there are simple way to fix the close latch without disassembling the monitor?
Chris
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
When you close the PB, a small hook-like thing comes down, and locks the clamshell (Though this isn't easilly visible) chances are, that that hook is stuck. You could use a piece of tape to prevent the hook from locking the clamshell, but it wouldn't stay tightly closed. It is unclear to me how the hook descends (whether it be gravity or magnetism) but it may be stuck in place by the latch mechanism, or may be slightly bent. You might want to try "Catching" it as you close the lid, and inspect it for damage.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Yates 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,280
