跳转到主内容
Model 1402 / 16 or 32 GB capacity
10 个问题 查看全部
Where can I find replacement parts?
I have a zune hd that took a hit in a skateboarding accident. The device is fine except for the ribbon cable that connects the audio output jack. Where can I find a new jack / ribbon? (4 solder points and I'm good to go! If I could only find the part.)
I think I can make it work with small gauge wire... but I'd rather have the actual part. Any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
Check this page for guides etc., but for parts, you'd have to search ebay, amazon, etc., and you'll find plenty of parts all over the place.
这个答案有帮助吗?
得分 1
添加一条评论
yea i need the same part myself, ebay doesnt seem to have it but i will keep looking
这个答案有帮助吗?
得分 0
添加一条评论
Anyone still interested in parts go to:
http://www.rapidrepair.com/shop/zune-par...
or:
http://www.repairsuniverse.com/zune-part...
I have used both of these vendors with good results.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
I have a Zune HD that I replaced the digitizer on and I cannot find the correct adhesive to put it back together. I tried using a (I believe it was an iPod touch) 3M adhesive but it was too thick and the glass digitizer wasn't flush with the bottom panel. I've had my Zune HD in a vault for almost 7 years and really want to get it working again. Any advise would be much appreciated
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shawn Porter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 8,669
