跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
问题已关闭
[SOLVED] LED light always on, what could be the reason?
My LED light on my iPhone 4S stay always on. I try to re-initialyze the phone without success on LED light (the camera flash in fact).
I have all updates done, and it doesn't change anything, even when I turn off the phone.
Otherwise it works well. The phone isn't cracked or breached.
Any solution ?
Thanks for your time !
Update
Testing with parts of my wife's iPhone... and it's working....
No problems with connectors in both parts
So I have to change for new part....
Final Update
Replacing Rear camera quite easily... and it works well now.
Thank you all for your disponibility !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I will check the camera to see if it works.... Maybe I have to change these ?
完成的
添加一条评论
4个答案
已选择的解决方案
Interesting problem, I have had 1 phone in my shop with this exact problem and it turned out to be corrosion on the motherboard (water damage) , I would disassemble your phone and inspect all parts and treat any corroded spots with alcohol and a toothbrush, good luck. iPhone 4s 拆解
这个答案有帮助吗?
得分 1
9条评论:
Thanks for your quick answer, but I'm sure that I never had water damage.
I'll try to disassemble it and inspect it... Wait and See !
完成的
Thanks I would love to hear what you find out.
完成的
Nothing special found after inspection of my iPhone...
No corrosion, all connectors OK, the liquid indicator is white....
Maybe it is an hardware issue ?
完成的
Yes, I would try replacing the Camera-led next, they are cheap, if that doesn't work you should try restoring it, several times if necessary, I know that's a pain but I have had to do that several times to make a camera work correctly, something else, if you don't have a flashlight app I would get one and see if you can turn the led off with the app open, keep us posted, good luck !
完成的
Hi ! It doesn't change anything with an App with flash, like iTorch.
I can turn on and off the light with the App. When closing the App, the symptoms are the same....
完成的
显示更多的4条评论
添加一条评论
Last time I had a wet phone with this issue I cleaned the connectors for the camera and it worked fine afterwards.
这个答案有帮助吗?
得分 0
1条评论:
Yes but mine wasn't wet at all !
完成的
添加一条评论
It is most likely a bad connection of the camera. Simply take off the rear plate and disconnect/reconnect the camera and that will fix it. GOOD LUCK!
这个答案有帮助吗?
得分 0
添加一条评论
Generally this is related to water damage. Replacing the camera might work, but more often when I see this finding corrosion on the board and cleaning it is what solves the issue.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 15
总计 35,727
