跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
How can I keep data on a disabled 2nd Gen iPod Touch?
My 2nd Generation iPod Touch was just found after years of being packed away.
It is disabled and I've read posts about how to unlock it but it requires a reset.
Is this the only way I can open my iPod? I have pictures from when I was in the Middle East and I want to open and save everything if I can.
Any apps or hacks?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Nicholas Hayden , here is a copy of my answer to a very similar question "
Connect the iPod to your PC using the supplied USB cord.
Open iTunes if it did not open automatically.
Click the Options button in the lower right corner of the iTunes window.
Click Enable USB Disk Use.
Go to My Computer and select your iPod.
Select Tools and click on the folder option.
Select the View tab
Select Show hidden files and folders.
Search for the "Ipod_Control" folder aka Settings
Look in a folder that is sometimes called "Device" and find a file named "_locked".
Change the file name "_locked" to "_unlocked".
Your iPod should now function properly. Also, make sure you disable iTunes from auto syncing. The other thing, you might look at this and try it. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
Will ur pictures delete in it?
完成的
添加一条评论
My iPod is disabled and I need to connect it to iTunes
这个答案有帮助吗?
得分 0
添加一条评论
Hello nicholas hayden i also forgot my passcode in a moment .and i have ipod 5 and i selected the hard passcode which is with letters in apple .now it says connect to itunes.i know how to restore it but is there a way for saving my pictures i have a stack of them with my frnds.plz tell me i will be very gracefull
这个答案有帮助吗?
得分 0
添加一条评论
You have to jail break it before doing anything against apple policies
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicholas Hayden 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 2,892
