Nipple on the bottom of the carburetor?
I've tried to loacate the schematics or pictures of the fuel lines on the carb. I replaced all of the missing hoses from when I bought it and there is a nipple on the bottom of the carb that leaks gas when I fill it. It's very small. What should it be hooked to? Also, the fuelcock drains gas in all positions from the hose coming off of it. Is it faulty? thanks for the help!!
3条评论
On inspection of my 60 hip Suzuki I noticed that the cooling nipple had corroded through flush with the block how can I repair this.
由 Geoffrey Fleming 完成的
Couldn't find a pit cock that had vacuum on it. What will I have to do about the two nipples on front of tank . Has one big one and one small
由 Chris Mills 完成的
Does anybody no where I can order the right gas cock with vacuumed that bolt holes from center to center are 2 &3/8
由 Chris Mills 完成的
