跳转到主内容
修复你的物品
维修的权力
商店
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
221 个问题 查看全部
broken fan connector 610-0164
Hello,
I have broken fan connector. I can not restore the sequence cables. Help me please. Fan 610-0164. FIXED! RIGHT LOCATION! Foto 3
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 2
评论:
Ouch! It looks like you broke the logic board connector, is that correct?
完成的
No, board connector is good, broke the fan connector
完成的
Hi, I had the same problem!
I have replaced the Harddisk for SSD
But i was lucky to get the cable back into the fan connector.
It took a long time to fix it.
China made...oh..boy?!?!?
It's a pitty to get bad quality connectors in the expensive miniMac
Good luck!
I hope you can fix it!
完成的
I am so mad at myself, I just want to bump the brand new mini's memory to 16G and put in a 500G SSD, I knew the fan connector is fragile, so try to be very careful not to break it. Sure enough, I broke it 8...( . Thanks for the posts here, I feel a bit better I am not the only one.
完成的
I broke the board connector of the fan... solved the problem by letting the mac mini open and put it on laptop table fan... been working like that for 3 years now :)Just saying in case someone has the same issue.
完成的
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
4个回答
已选择的解决方案
Apple doesn't sell discreet parts like this. You could get a new fan assembly which would have a working connector that would be the easiest way but might be costly and difficult to get depending on where you are located.
Sorry to say, I don't know the make & part number of the connector it's self to see if you could find a replacement from other sources. You could try searching the web here's a few manufactures of connectors you could search under: Molex, AMP & Tyco.
这个答案有帮助吗?
得分 1
评论:
Hi all, I ordered the 4 pin EZmate Molex wire to board connector from mouser.com. Part number 538-78172-0004. I ordered 5 just in case. Replacing it took a few minutes and my Mac Mini is back online with the fan operational. I had to pay EURO 20 in shipping charges, but hey iFixedIt!
完成的
添加一条评论
最有帮助的答案
Since I am not a Mac person, take this advice as a general one. Take a look at your connector, you should see an opening on the side of it. the copper connector had a little hook that will push inside the plastic connector. Push a needle into it and pull the cable with the connector out. When you have the cable with the connectors pulled out of the plastic, it should be possible to simply push them on the male counter part on your board. Once pushed on, cover the exposed ends with electric tape....
这个答案有帮助吗?
得分 2
添加一条评论
The connector attached to the wires is a Molex brand pico EZmate connector. I also messed mine up while doing the SSD upgrade. Luckily I managed to put it back with a piece of tape like @oldturkey03 suggested. I will try to order a few from rs-online.com, but I am not sure they sell these in low quantities. You should be able to pry out the pins of the broken connector with that needle and use a new connector housing without having to crimp the connectors again with a special tool. I'll let you guys know if I manage to get a new one. Cheers.
这个答案有帮助吗?
得分 2
评论:
Good find Paul.
完成的
For the motherboard connector - Molex Part No from RS is 700-0833, for the connector on the fan lead Molex Part No from RS 700-1025. Happy soldering!
完成的
How do u put it in to the logic board? Any link plsv
完成的
belskhie confused by your question. It needs to be soldered to the board.
完成的
添加一条评论
Hi
Those 2 metal pins on either side of the connector - Do they do anything or just help secure the whole connector to the board? I know the 4 pins in the middle are for the fan.
Thanks
这个答案有帮助吗?
得分 0
评论:
They have no electrical function. They help secure the connector to the logic board so you you don't lift it off.
完成的
添加一条评论
添加你的答案
zaa495 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 10
过去的30天: 38
总计 8,642
