Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
105 个问题 查看全部
Have to push down charger to charge dsixl
Hello
My dsi XL will not charge unless you push the charger
For it to charge and have short battery life.
Is there any way that you can help me? Thank you
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Mine is doing the same thing!
I have to press down onto my DSI XL charger in order for it to charge, and then sometimes wrap the cord around my DSI and it sometimes works, or my DSI is f***** up, I don't know.
@xJDogsBabex, just like previously answered; replace your charging port.
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Dsiwontcharge, from the way you describe it, it does sound like a bad charging port. It is soldered onto the logic board. Follow this guide to get to the port. Check for any loose/cracked solder connections as well as any damage to the logic board. Replace the port and re-evaluate. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Dsiwontcharge 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 653
