跳转到主内容
型号A1288,闪存容量:8、16及32GB
449 个问题 查看全部
问题已关闭
What's the best way to take off the front glass?
I've tried starting from the side by the volume buttons, and tried starting near the bottom, but haven't found a really good way to take off the front glass.
It works best for me to use a metal spudger, but you have to be careful or i've dinged up a couple LCD's this way, so then I go back to guitar picks But until I get a few of those latches off, it's just really tricky.
Any outstanding advice on the subject? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Wow Thumbnail!! Which way do you face the inside of your thumbnail? Towards the metal edge or towards the display?
The corners of the second Gen are what mystify me. They seem really tight even though I realize there is not a latch in that location.
So far I used the plastic tool with the right angle edge to more or less pull the metal edge of the iPod back slightly so I could reach in there with a flat blade screw driver and attempt to release the latch as per instructions on this site:
http://www.pcxmedics.com/blog/diy/cracke...
I would say I got the touch screen up maybe 1 mm above the metal side . Probably this is all the height I will gain until I get more latches released. But already I can see where the flat blade screw driver has slightly blemished the metal edge of the metal back.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I use a thumbnail (no joke) and I start at the corner. But there's pretty well no way around the fact that this is one tough cookie to get into. :)
这个答案有帮助吗?
得分 1
评论:
haha no kidding.. well which corner do you prefer to start at?
完成的
I believe I start at the lower left, though I don't have a specific reason why.
完成的
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 3,076
