跳转到主内容
The Samsung Intercept SPH-M910 is a midrange Android smartphone sold by Sprint, marketed as a newer, more affordable version of the popular Samsung Moment. Released in 2010 with Android 2.1 Eclair.
6 个问题 查看全部
问题已关闭
How do we upgrade Ram?
Can we upgrade the ram? If so, how complicated is it to do ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Steve Haynes, the Ram is contained in an IC. It is soldered onto the logic board. There is no easy way of changing it. It is an intergrated part of the logicboard. Unless you have a rework station, know how to reball IC's and have an IC that has the same layout, it is almost impossible.
这个答案有帮助吗?
得分 0
添加一条评论
The best way to improve performance similar to installing RAM would be to use a larger sd card. If your android phone is rooted you can go even further by partitioning your sd card and making a swap partition, which basically acts as RAM. Many ROMs require a swap partition to run the more resource intensive features of newer phones on older hardware like the intercept. Cleaning out unused data and restarting phone daily can also give you minor performance benefits.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 993
