跳转到主内容
修复你的物品
维修的权力
商店
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
624 个问题 查看全部
Why no guides for this?
I just purchased one of the last MacBook Pro 17", Unibody Late 2011 models with a 2.4Ghz i7 quad core. I was hoping to be able to get your help with replacing the hard drive, and the optical drive. Why no guides for this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
That is a bit odd that the guides haven't been completed for the newer models but I can tell you that the process will be almost identical to the MacBook Pro 17" Unibody Guide. The only differences I can think of is that the battery may be different (may have to remove in order to disconnect, requiring either a tri-wing or pentalobe driver) and the Airport card may be mounted just above the optical drive. Both of these are pretty straightforward when looking at them though.
The Airport card / carrier removal should be very similar to the process for the 15" MacBook Pro Early 2011
Hope that helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dave 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 370
