How to remove a stuck screw
I want to upgrade ram on my MacBook Pro but i have a screw not stripped but i can not remove it it is stuck i think that it is glue inside. My MacBook Pro is a 13 inch i7 2.9ghz, 8GB ram and 750GB hard drive.
Make sure that you are using the correct tool, it should be a "000" precision tool, you might be able to get away with a "00". Its important that you use the right tool so that you can apply a good amount of pressure and try to turn it without the screw driver slipping out of the head of the screw. Hope this helps!
这个答案有帮助吗?
Can you give to me a link to buy this tool please.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,446
