跳转到主内容
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
74 个问题 查看全部
dash and tail lights not working. Does it have a taillight relay?
All lights work except Dash and taillight. Fuses were good. is a tail light relay
relay?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 19
15条评论
same problem 1998 ford expedition
完成的
i have the same issue dash light and parking lights dont work i need help bad
完成的
Celica 1993 it's the relay switch drivers side pull cover back and just above the fuses is two red relay switches it's the one on the right I did it last night and then all light and dash lights came on
完成的
The relay behind the glove box was out of the socket and I had to push it in to make the connection. My 2007 Matrix tail light would not work. Fuse was okay and bulbs were new. The hardest part of the job was to find the fuse boxes and relay box (fuse box underneath hood, under driver side and relay behind glove box).
完成的
I have a 1992 Nissan maxima my tail lights don't work, I checked the fuses and the bulbs are good. The relays under the hood I checked and there also good. Tail lights still don't work. Brake lights and headlights work also. Any tips for me
完成的
显示更多的10条评论
添加一条评论
6个答案
已选择的解决方案
theresa, this is what the manual has to say :
Symptom
Both tail lamps do not come on (Headlamps are normal).
1. TAIL fuse
2. TAIL relay (USA only)
3. Headlamp dimmer switch assy
4. Daytime running light relay (USA only)
5. Wire harness
The tail lamp relay is relay number B, 2md from the left in the RH junction box
15. TAILLAMP RELAY
(a) Measure the resistance according to the value(s) in the
table below.
Standard:
Tester connection Condition Specified resistance
3 – 5 Always 10 kW or higher
3 – 5
Apply B+ between terminals 1 and 2 Below 1 W
If that is not the cause, I would check the headlight dimmer switch (sounds more like it because of your dash light being out as well
Hope this helps, good luck.
这个答案有帮助吗?
得分 8
9条评论:
I think it will help but my car is kia shuma do have any idea? It has the same problem
完成的
ngutjiua kauhonina what year is your Kia and exactly what is going on with it? what have you tried?
完成的
I have a Mitsubishi Montero Sport 2001 have break lights and flashers but no tail lights or turn signals or park lights witch fuse do I checks there not marked very good on cover
完成的
I have a Buick LeSabre, while I'm in park all my lights works fine. But as soon as I put the car in drive the right head and tail lights want work!
完成的
Nailed it! ... and... SOLVED.
2003 Mitsubishi Lancer OZ Rally
Found the rear tail light (parking light) fuses [aka Tail Lamp Relay], right here in the engine compartment, but they were individual 7.5A fuses.
If you have the fuse cover, there are symbols implying 'parking lights' and very NON specific, but i pulled these fuses, to find them blown, and replaced with 7.5A mini fuses.
We are FUNCTIONAL, and working, like a magic lava lamp!
HooYah!
Thank you so much!
完成的
显示更多的4条评论
添加一条评论
2006 Toyota Matrix. If your dash lights work but won't dim and your running light won't work and your license plate lights are out. Then there are 4 relays directly above the glove box. you can't see them until you drop the panel. There are three 10mm bolts just in front of the latch. There are 4 relays, 3 that look the same and one that is different. The relay that you want is the middle one of the 3 that are the same. I hope this helps
这个答案有帮助吗?
得分 6
4条评论:
I have a 2005 Toyota Matrix No Tail Lights No front parking lights Dash lights did not dim. No tone when lights were left on. Saw this post after several hours of self diagnosis Changed the relay and everything is back to working order. Thanks to Mark B. You Are The Man.
完成的
DAYS OF kicking my own butt on why i cant find a dang short or bad fuse way to go toyota ur the best at hide and seek parts that should be obviously placed
完成的
Where is the relay located?
完成的
I have a 2005 Toyota prius and my taillights are not working but my breaks flashers and headlights are working fine I just changed the bulb and checked the fuse what can it be
完成的
添加一条评论
Hi all,
I have the same problem on my corolla ascent. I found the thimble switch on the steering column to be sticky/ dirty. They are little fingers/ platinum points that needed to be cleaned with some fine sandpaper. Also bending the fingers will also help to give better contact for the lights. There are 3 fingers and the middle one is for the park & tail lights.
Hope this helps resolve your problem.
Sakthy.
这个答案有帮助吗?
得分 2
3条评论:
I have the same problem on my '95 Mitsubishi Montero dash lights won't come on or running back lights but hazards work in the back as well as when I brake the front lights work , I tried the fuses they all work and the relay works because the front lights work plz can someone help me plz !!!! Tia
完成的
Almost the same problem . pls help
完成的
how do I remove the thimble switch
完成的
添加一条评论
If your car was damaged to the front and you had to repair any wires, you may connect 2 identical wires together. Also you can mess them up very easy when you connect aftermarket stereo system. They could be identical but wrong wires. Recommend to recheck them at those places that you where working on.
这个答案有帮助吗?
得分 0
添加一条评论
My Auris did the same. Park and tail lights not working and the rest worked. I removed the air bag and steering wheel. Removed the light and wiper unit from the steering column. Opened the lighting unit and lightly sanded the contacts and my problem was solved.
这个答案有帮助吗?
得分 0
2条评论:
I had my lancer sedan 97 dashboard light and parklight suddenly went off while driving, flashers were working fine, break does, head lights on, managed to get home, checked the parkng light bulbs, checked fuses under hood and under drivers kick panel everything were good, checked relays too, pls help what else to do to fix this problem
完成的
Hey everybody same is issue I bought a 04 tiburon and the power windows, dash lights, signal lights, and tail lights don’t work but my brake lights come on. I replaced fuses the bcm and still no luck any ideas?
完成的
添加一条评论
My 03 camry had the same issue. No gauge lights, tail lamps, and no parking lights. The tail lamp relay is on the back of the fuse box ( middle one on the outside,) but that wasn't the problem. Under the hood I swapped the horn relay with the ECU relay and it fixed the problem. Those relays are side by side and they're all the same.
这个答案有帮助吗?
得分 0
1条评论:
hi i have mitsubishi lancer glxi 4g92 and 1993 model,, my problem is the dash light and park light on left side did not work while the right park light is working... i need ur help to fix my problem on my car... thank you in advance..
完成的
添加一条评论
添加你的答案
theresa 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 111
过去 30 天: 407
总计 282,057
