跳转到主内容
修复你的物品
维修的权力
配件 & 工具
A compact digital camera released 09/15/2005.
11 个问题 查看全部
sd card won't come out of camera
The sd card is stuck in the camera. Any ideas as to how to get it out. Have tried tweezers and it still won't come out keep pushing but no luck getting it to pop out as it normally does.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
2个回答
最有帮助的答案
Hi, I think the spring mechanism might be jammed. What u need to do is push the sd card down gently and gently turn the card, and try to pull the card out. The key is patience and be gentle. Write back on what u did. Good luck.
这个答案有帮助吗?
得分 1
评论:
thanks it worked
完成的
添加一条评论
I have the same issue & I got its solution later. So i can help you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Molly 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 1,842
