跳转到主内容
宏碁在1997年购买了德州仪器的移动PC部门,从此进入了笔记本电脑的世界。
1682 个问题 查看全部
Won't turn on, just blinks 5 times
Acer Aspire One was on battery x 3 hours and went 'off'. OK, so I plugged it in to ac power source and it still wouldn't come on. Took battery out, plugged the comp into power source, nothing. Waited over 12 hours and tried again = nothing. With the battery in and plugged in, power button light blinks 5 times and nothing
With the battery OUT and plugged into power source, power light blinks 5 times and nothing.
--- This computer is maybe 6 months old. Yes, I'll go to the store, but I'm extremely disabled and it will take two days of prep and arrangements to get me there so oh please help me do this at home. Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
I had same problem , drove me mad after changing everything I found out the extension socket I was using worked fine on other appliances but for some reason wouldnt charge battery so blinking 5 times means battery too flat, just plug into wall socket and worked fine, but drove me mad trying to find it. good luck, 5 blinks is flat battery
完成的
添加一条评论
1个答案
已选择的解决方案
Here is a link to the service manual for your computer. Hope it helps. Good luck.
http://tim.id.au/laptops/acer/aspire%20o...
这个答案有帮助吗?
得分 1
2条评论:
Furnishing a link to the unit's service manual does not qualify as an "answered" question.
完成的
@clinton Agreed, useless
完成的
添加一条评论
添加你的答案
Doctor 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 53
总计 36,796
