Error no partion found grub rescue
Help I HAVE NOT GOT LINUX INSTALLED AND I DON'T HAVE WIN 7 INSTALL CD OR LINUX LIVE CD
Hi, can u be a little more specific. Did u install install linux before? Also use another computer to create a startup disk. I doesnt need to be Windows 7, you can download Windows ME startup disk. and enter the following commands in a command prompt; Write back what u did. Good luck.
1) Boot with your Vista/Windows 7 installation disk. Hit <Enter> at the language selection prompt then hit <R> for Repair to get to the Repair section.
2) Select the command prompt (console) and type in the following commands:
BootRec.exe /fixmbr (#updates MBR master boot record...do not run if you still want grub)
chkdsk /r
BootRec.exe /FixBoot (#updates PBR partition boot)
BootRec.exe /ScanOs
BootRec.exe /RebuildBcd
这个答案有帮助吗?
Installed windows first and Linux second it was working for 6months and then it said the error the only thing I care about from wiping my computer is itunes
Ever heard of hirens boot cd? It is a very valuable asset to have in any environment. You can download it free on the net burn the ISO to a disc and boot your CPU back up. In addition to that, it has numerous programs from partition recovery (which sounds like would help you) to MBR repair antivirus scan photo recovery etc etc. check it out man if you need some help getting it going let me know. Otherwise good luck!
Oh btw. Do your homework on these programs before you start to run Em on your cpu. And use an external hard drive to save all your recovered data on.
这个答案有帮助吗?
I can't burn hirens boot cd Iso because I don't have a computer only an iPod
Where can I get it from Cous pirate bay is blocked
Don't have any space left as I'm using a library computer with no admin controls
can't download it if you do not have a computer:(
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,254
5条评论
It did then it done it again plus I lost all of my files
由 Jamie Bishop 完成的
That's the prob I don't have install or recory cd
由 Jamie Bishop 完成的
Oh no I'm doomed and I haven't had that for a year (well its a year old on the 11th of nov) :(
由 Jamie Bishop 完成的
Deleted no partitions and have not messed with them either I installed Linux 6months ago and uninstalled it 5monts ago do not have this error
由 Jamie Bishop 完成的
Do you still get into windows at all? try to hit F8 a couple of times when you power your computer up.
由 oldturkey03 完成的
