跳转到主内容
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 个问题 查看全部
How to remove dash panel to replace Radio
Trying 2replace the cd deck. Dash seems simple to remove but the trim panel wraps round the ignition hole. How do I remove the panel without damaging it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Dee brown, check on here for a broken down service manual. the instrument cluster removal is described in the "BO" file. Hope this helps, good luck
这个答案有帮助吗?
得分 1
3条评论:
That was exactly what I needed. Truly, truly, appreciate it. Got a few other things 2do on this car as well & this has all the answers. Thank u, oldturkey03. Ur a scholar & a gentleman
完成的
you are welcome :-)
完成的
hey I have the same problem. what do you do to unlock the clips
完成的
添加一条评论
添加你的答案
Dee Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 6,754
