跳转到主内容
MacBook Pro 13寸显示器版本
9729 个问题 查看全部
Black screen one beep
Hi I have a Macbook pro I am getting power however the screen is black and i am only getting one beep every 5 seconds. I can not find any information for one beep.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
So what fixed your issue?
My MacBook Pro boots up. Looks like it is working fine. But after a while, sometimes 5 minutes and sometimes 30 minutes, its screen turns black and I get a single beep every five seconds. I can manually power off the MacBook, and restart normally but the same thing happens after a while.
完成的
Replaced or reseated the RAM modules.
完成的
添加一条评论
1个答案
已选择的解决方案
First try the following: Resetting NVRAM and PRAM
If that doesn't help you may have a memory issue see this TN: Beep error codes
这个答案有帮助吗?
得分 2
1条评论:
Thanks this is what i needed
完成的
添加一条评论
添加你的答案
Shodanime 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 23,795
