跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
Possible to install a Retina Display on an Early 2011 unibody MacBook?
My early 2011 unibody Macbook pro 15" LCD broke.
While I am now researching how to fix it by myself, it came to my mind: is it possible to install a Retina Display on it?
What would make it possible? And what wouldn't?
Many thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Unfortunately, the simple answer is no. The graphics card would have issues running the display if you were even able to instal it. The Retina display MacBook Pro also has different connectors and dimensions then the regular Macbook Pro and therefore not fit and not connect. The firmware for you computer will also not scale the resolution and render properly so you would have a 1440 x 900 resolution displaying on a 2880 x 1800 display which would only take up 1/4 of the display. I wish it were possible but it just isn't. You will have to replace it with a regular 15" 2011 panel.
Hope this Helps
这个答案有帮助吗?
得分 2
2条评论:
and what about replacing it with display with slightly more pixels (1600x900, i guess) with anti-glare layer? does it fix and how difficult this operation is
完成的
personally wouldn't risk it I saw someone plug in a wrong screen into MacBook pro heard a fizzle and a pop and both logic board and lcd cables were damaged never had video though lcd again had to run on external screen all the time after that
完成的
添加一条评论
添加你的答案
marcelpace 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 9,469
