跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
How to reconnect a zif connector for trackpad?
Hello everyone,
I just open my macbookair to clean the keyboard (i spill some coffee on it :/).
The only problem is that i dont know if the connector is connect in a good manner. I try to push it and it seem to be correctly connected. I would like to know how i can be sure that the zif connector is connected? If it not connected, how can i connect it?
Thank you very much.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
To make sure that your ribbon cable is seated, first gently flip up the locking tab on the backside of the ZIF connector (opposite from the cable). Insert the cable as far as you can, and while holding it in place, push the locking tab back down into place. Be patient and never use too much force, because a broken ZIF connector could be the difference between a fixed computer and a giant paperweight.
这个答案有帮助吗?
得分 2
3条评论:
Thank you very much David for the answer. Just to be sure, there are locking tab in the trackpad connector?
Thank you very much
完成的
The trackpad connector does have a locking tab ZIF connector, as seen in the first picture of this step: MacBook Air 13" Mid 2011 Trackpad Replacement Guide
完成的
thank you very much. Never saw this locking tab.
i got a new problem: trackpad is making noise
Thank you very much again.
完成的
添加一条评论
添加你的答案
bongshu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,683
