跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2192 个问题 查看全部
问题已关闭
iPhone 4S won't turn on after Battery removal and reinstallation
Hello,
My power and volume buttons were getting loose so I had to open my phone up and tighten those screws, I had to remove the battery and the shield to get access to it. After putting it back together it wont turn on! I did double check every flex cable/connector, and checked if the battery was properly fitted so I know that isn't the problem.
However the screw holder that would screw in to the top part of the plate that covers the battery & antenna shield has fallen out, and I am wondering if that could be the possible cause of my phone not booting. If not, what could be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
salam...
maybe you broke the battery connector in the process which is difficult to fix. but before jumping to conclusions hard reset the iphone which happens by holding and keeping on pressing both the sleep button and the home button at once until the apple logo shows up.
Malik.
这个答案有帮助吗?
得分 0
1条评论:
I've already attempted the hard reset
完成的
添加一条评论
Try taking out the battery and plugging it into the wall via USB. Don't use a computer, plug it into a wall outlet.
这个答案有帮助吗?
得分 0
1条评论:
Won't turn on, so could this be an issue with the logic board then?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,891
