跳转到主内容
加入维修社区 - 创建账户
三星 S860 是一款高分辨率数码相机,具备 810 万像素、3 倍光学变焦、三星 SHD 镜头、2.4 英寸液晶显示屏以及数字图像稳定 (DIS) 功能。
Why won't my camara turn on?
I have put new batteries in and checked they are the right way round. When I press the power switch the camera status lamp on the back flashes green but nothing else hapens. As soon as I take my finger of the power button the flashing stops even if I hold the power button down for several seconds (approx 20).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
does the screen receive power?
does the lens extend?
did you buy it new or used and where?
由完成的
This Camera Won't Turn On
由完成的
添加一条评论
1个答案
Helen Smith, check your lens. Make sure it is properly retracted. Check the clearance of the lens against the housing. It should be equal all the way around. The camera will shut off if the lens does not extend or retract. If that looks okay, make sure that you battery connectors are not corroded and the the door contact touches both batteries. If that is okay, you may have to take it apart and take a look at the individual components. It is possible that your DC-DC IC has issues
这个答案有帮助吗?
得分 0
2条评论:
Thanks. The lens doesn't extend, and the screen doesn't recieve power. I bought it new approx 4 years ago, and it worked fine last time I used it. The camera has been untouched, but safely stored in a protective case for about 2 years. I don't take many pics!! The clearance of the lens look ok The battery connectors look ok and the door contact appears to touch both batteries, so it looks like a repair job is needed. Thanks for the advice.
由完成的
Old turkey 03, or Helen Smith, I have the same problem. I have recharged the batteries and connections look good. Stored it good place for I don’t use it that much.worked good 4 months ago. But lens won’t extend.so do I go to repair shop or what? THY.
由完成的
添加一条评论
添加你的答案
Helen Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 14
过去 30 天: 27
总计 4,636
