跳转到主内容
修复你的物品
维修的权力
商店
The Kindle 3 was the 3rd generation of Kindle produced by Amazon. It can in a WI-FI or 3G configuration with 4 GB of internal storage.
72 个问题 查看全部
Kindle 3 g Repair
The screen shows the screen saver that appears when the device is shut down the device does not turn on to read. The on off switch appears to be ok can anyone suggest a solution . New screen? Have tried to reset device numerous times also removed battery in an attempt to reset
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
2个回答
最有帮助的答案
Make sure that battery is connected properly, I'd bet your messing with it disconnected it or similar.
I'd advise leaving it to charge for several hours, to ensure it's charged.
Then go for a hard reboot, hold the power switch and keep it held, after 30 seconds or so (sometimes more than a minute) the device should reboot, which almost always works.
If all this still doesn't work, I'd advise getting a new battery (though before buying one I'd suggest contacting amazon's customer support, often they'll just do this stuff for free).
这个答案有帮助吗?
得分 1
添加一条评论
Do you know who can repair my kindle
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,897
