跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
What could possibly cause my sound problems after reassembling?
Hi all,
I have the following problem:
I changed the proximity sensor/power button flex cable in my iPhone 4 GSM device and reassembled it. The power button works, but some additional problems came up...
- When talking to others on the phone, they are extremely quiet (tested with different partners).
- When talking on speaker phone, they cannot hear me.
EVERYTHING else works fine (did a long extensive testing).
I noticed that the piece marked with the red arrow on the uploaded picture is damaged. It broke at around the red line. It has not come off, but it is definitely not in original state.
http://imageshack.us/scaled/landing/826/...
What does that piece do? Could that cause my problems? What else could have gone wrong?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Kenzo, I think for your earpiece there are no need to change it, just adjust your earpiece proprely.
But for the mic, I think the problem comes from the flex you replaced, you have to change it. Maybe the new flex is not good.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the information, I will try to replace it sometime.
Which part of the flex cable is reponsible for the speaker mic?
Btw, you were right about the earpiece ... it now works. Thanks again.
完成的
The mic on the flex is the gold color part.
完成的
添加一条评论
添加你的答案
Kenzo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 498
