跳转到主内容
Model A1138 / 1440x960 screen resolution
97 个问题 查看全部
Do I need to add thermal compound?
Hi
I am about to perform an installation of a new logic board in my machine, and when I pulled the old one out, I noticed thermal compound was on the heat sink under the ATI Graphics module, as well as under the processor. I bought a used board off eBay and it there is compound on the processor and graphics module in the photo on the advert, however, there is absolutely no mention of this on the iFixit guide? The guide only mentions adding thermal compound to the heat sink where the processor is.
Thanks ;o)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个回答
已选择的解决方案
Here's all the information you need on Thermal Paste: 如何涂散热膏
这个答案有帮助吗?
得分 1
评论:
Thank you Mayer, however, I have already seen that guide and performed it successfully on quite a few other PowerBooks, but they didn't have the 128MB ATI graphics that this machine does, and they only had thermal compound on their processor, not the graphics card. The heat sink on this machine does have two copper plates, one under the processor and one under the graphics card. I suspect that I will need to apply paste to both areas, but as it isn't described as such in the iFixit guide, I wanted to make very sure before I make a mess of things. I thought, when I pulled the faulty logic board from this machine (which has a short circuit), that the short may have been caused by compound being on the graphics card too. Then I saw the eBay picture of the logic board I just bought, and noticed compound on that graphics card too! Thanks again! ;o)
完成的
I really don't remember seeing this problem before. Do you have the Apple part number on the logic board? Maybe I can help you do some research on this.
完成的
The Apple part number is 820-1940-A.
And here is the eBay item with photo showing graphics card in the top centre and processor top right, both with paste residue on:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...
完成的
I have this machine in my parts pile and saw the reason they missed it in the teardown, it's on the bottom side of the board. Mine has paste on it also. So I would replace it.
完成的
Thanks Mayer, your help is greatly appreciated. ;o)
完成的
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 1
总计 2,030
