跳转到主内容
Bizzare Display malfunction, can anyone help please?
Hello, so a few days ago, my Macbook 2009 Unibody 2ghz started doing this (I posted a Video of it on youtube):
http://www.youtube.com/watch?v=FJgwxOkRU...
The macbook boots fine, works fine, even the display, until i start flipping the lid. As soon as there is a minor movement, the screen starts to fade. At the next startup, everything is fine again.
Can anyone help me, or tell me how i could fix this? (I know how to dissasemble the display ;))
Thanks for your help, I really appreciate.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
It must be something with the display cable, look at step 8 on the guide:
MacBook Pro 13" Unibody 中期显示屏更换
Something similar happened to me with a dell, the data cable had an issue and it would make the display go crazy in colours.
这个答案有帮助吗?
得分 1
添加一条评论
I agree.
Typical of a broken video cable in the hinge.
You can see the artifact column on the left as you are touching it and then the signal is inverted once you push it farther back.
Question is if one can order & replace the cable itself, without the screen? As the assembly is $$$.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thierryl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 260
