CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
424 个问题 查看全部
Home Button Without Replacing Cable
I want to switch colors of my digitizer. The kit I am looking at just has the button not the whole Home Button Assembly. How is this button held on to the cable, the standard adhesive they use to hold other parts on? Do you remove the button with a heat gun? TIA
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Yes, it is held by the standard double-sided adhesive that Apple uses in many places of the iPhone. Gentle use of a heat gun can be used but is not necessary. Just carefully pry the Home Button part you touch from the Ribbon part.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
AddDumb 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 386
