跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
My drunk friend slept with my iPhone and peed in his pants
My iPhone 3GS was pee'd on by my drunk friend who slept with it the other night at a party. He didn't tell me till the next afternoon which the camera was still moist and foggy. So i dried it up but idk if he tried turning it on. Two days goes by and nothing works, so i decide to open it up and look at the logic board and the copper contacts attached to the battery are corroded and have like little dark spots. i sprayed little amounts of contact cleaner and cleaned them up brand new but nothing. I'm charging it now but still no luck.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 34
11条评论
Sounds like your friend owes you a new phone.
完成的
I agree with Ben- he should replace the phone for you.
And maybe don't let him borrow it again...
完成的
Third that- what was the phrase from that question? "replace the friend"?
完成的
I have to say though, this question had the most hilarious and most unfortunately misleading title I've yet seen.
完成的
He might be the "friend". lol
完成的
显示更多的6条评论
添加一条评论
8个答案
已选择的解决方案
Wow, you have some of the worst luck I've heard :(. Looks like you'll have to either replace the logic board or get the unit replaced. Replacing the logic board will be difficult, expensive, and require a lot of time and knowledge, if you have any way of getting it done or replaced by apple I highly recommend you do so.
You may have to replace some other parts but the logic board is the first step. You'll probably need to get a new battery, and maybe even a camera.
One of the main problems here is uric acid is an acid and therefore corrosive, so you'd best work quickly to make sure it's all cleaned up first, so nothing more is damaged.
Good luck, and be sure to check out the repair guide to help you take it apart.
这个答案有帮助吗?
得分 17
3条评论:
I hope its the battery thts what im gonna replace first :\
完成的
Seeing as you saw obvious evidence of damage to the logic board it would be a waste of money and time to do that first.
完成的
Even if it does function with a new battery, it will only be a matter of time, or you will be restricted to limited functionality.
完成的
添加一条评论
What a pizzer! I repair liquid damaged phones all the time. First I don't like contact cleaner on iPhone logic boards for a number of reasons, but too late for that. I'd suggest if you haven't done so yet, remove the logic board totally from the housing and thus removing the battery from contaqcting the logic board before proceeding with any cleaning. Then using a VERY small screw driver or dental pick, pry the metal heat shield off the logic board (VERY CAREFULLY) there are small capacitors that can be damaged if pried against, take your time.
Use 91% Isopropyl Alcohol and a clean toothbrush to clean any residual corrosion, oxidation and urine traces (haha) from the board. Then put it together and try again to power it up when dry. Do a hard reset (power and home together) sometimes with water damage it puts the phone in DFU mode or a similar state of semi-conscious behavior (sort of like your friend!). You might also have a bad dock connector,thereby preventing your phone from being recognized by a computer when plugged in (even if in DFU), charging battery or allowing the home button to work properly, therefore no hard reset ability and leaving you stuck in DFU and not able to get out. Might be worth the $20.00 cost of a dock assembly to replace it if all else fails
Good luck...Chad
GURUmicro.com
这个答案有帮助吗?
得分 10
添加一条评论
My soon to be ex-husband had a hissy fit and threw my iPhone in the deep end of our pool!
I allowed him to purchase a brand new one for me, but held on to the old one.
I took out the sim card tray and left the phone in the warmest place I could find that was without humidity.
Every once in a while, I would plug it in to the wall adapter just to give it a little extra warmth... but not for very long
About 2 weeks later, my new phone started acting up on a holiday weekend.
I pulled out the drowned phone, plugged it in, charged it... and it works perfectly. The battery did hold a charge as well... but that is easy enough to fix.
I can't say that I would go to all of that trouble for a phone with pee. Turn it over to the carrier and they rebuild them for the military. If it's just water, however... give it your best college try!
这个答案有帮助吗?
得分 7
添加一条评论
My co-worker dropped her iPhone into the toilet. She retrived it and it was quite heavy from the water. Another co-worker said she read if you place the phone in a bag of uncooked rice, it will absorb the moisture. I was doubtful, but the next day she came back to work and the phone worked after it was in the bag overnight and she plugged it in to the charger.
这个答案有帮助吗?
得分 3
添加一条评论
Seems to be a common problem since Bell are now offering a plan for free iPhone replacement in second year of ownership if water damaged. I assume this includes getting p****d on!
这个答案有帮助吗?
得分 3
添加一条评论
Apple has an iPhone exchange program for iPhones out of warranty or damaged caused that voids the warranty.
My friend did this, gave them $250 and the old iPhone and they replaced it with a new one...
But not sure if they got this program in the States, this was done in Australia.
Might be worth checking out, before spending all this money buying replacement parts
这个答案有帮助吗?
得分 2
添加一条评论
Can you fix the phone
这个答案有帮助吗?
得分 0
1条评论:
what phone? what happened to it? try to be really descriptive and let us know what is going on with your phone?
完成的
添加一条评论
My phone enter the water closet full with pee
Engineer could not repair it. What can I do to it please?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hippo3 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 23
总计 73,248
