跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 Rear Panel Replaceability
How repairable is the rear case of the iPhone 5? And what is the cost? I know that it is virtually shatterproof, but it also scratches significantly easier than the glass panel of previous models. If the rear panel is expensive and difficult to replace I will probably use a case, but if it is relatively inexpensive and easy to repair then I would rather take on some scratches and put my money toward an extra rear panel. What do you think?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The phone starts with the aluminum unibody (rear case), and every single component is then placed and layered into it. Replacing the rear case literally involves removing every component from the phone. Add that to the fact that an OEM quality rear case with a sapphire camera lens cover won't be cheap, and you've got yourself a time-consuming, risky, and costly repair. Spend $30 or $40 on a good case if the scratches are going to bother you that much.
这个答案有帮助吗?
得分 2
添加一条评论
I replaced one. It will cost about $100 and more than 2 hours. But it works
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dbloxjunk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,178
