跳转到主内容
1.83Ghz logic board into 2.2Ghz MBP, possible?
I am looking at putting a working logic board from a working (and dirt cheap) 1.83Ghz MBP 2006 15" A1150 into my current, faster 2.2Ghz MBP 2008 15" Model A1226/1260 that's logic board is dead. Is this possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
If you put the 1.83 logic board in the 2.2 chassis then it would operate at 1.83 not 2.2....the cpu from the 2.2 would not work in the 1.83 logic board (different bus speeds)
Plus the board would not physically fit.
这个答案有帮助吗?
得分 0
2条评论:
Would there be any other type of Logic Board, other than the one made for this (which contains the nVidia GeForce 8600 chip that is so troublesome), that I could use instead?
完成的
Unfortunately, no. The only other boards without that graphics processor are the A1150, A1211, and Unibody boards, and none are compatible. Sorry!
完成的
添加一条评论
最有帮助的答案
Unfortunately, just about every connector was changed between these models, so it's not possible without swapping out most of the other parts as well.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Sue 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,349
