跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone fell from 1 foot, doesn't work anymore.
Hello everyone!
My iPhone fell from about 1 foot, the display is black, like it has been turned off. Since then the iPhone became very hot, but has been cooled down now..
I tried to turn on the phone: nothing happens
Held homebutton and powerbutton: nothing happens
Plugged into a computer: nothing happens.
I hope it's something with a display-connector that isn't connected anymore, but would that declare the intense heat it produced since the fall?
That comes to my second thought, that there can be some damage to the motherboard.
Does anyone else have any ideas?
I would very much appreciate it!!!
Kind Regards,
Gertjan
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
I'm not sure, because I can't see your phone.
Try to unplug your display data cable and plug it back properly.
Here the guide for you :
iPhone 4S 屏幕更换
Reboot your phone.
If it doesn't work, then you have to change it.
这个答案有帮助吗?
得分 1
6条评论:
Finister, something important to tell is, that he keeps rebooting, if I plug in the phone. I keep on hearing the boot sound, but nothing happens on the display.
I can see him on iTunes, but i can't restore..
I tried entering, fixing and exit recovery, but still no success.
On iTunes a message pops up, that the device isn't 'legible'.
完成的
Doyou see cracks on your screen? Or white or colors lignes on your screen?
完成的
Finister, no cracks, no white/colored lignes :(
Can it be something with the logic board? However, my Ifixit Pro Tech kit got delivered today, and now the pentalobe bit is damaged so i can't open up the iPhone... Now it's waiting for the single pentalobe bit to arrive.
But already a big thanks for your info and cooperation!
完成的
I don't think so Gertjan De Mulder, in worst case I think you have to change your display assembly. There are very few chance for the motherboard to be affected, your iPhone fell only from 1 feet high.
完成的
Finister, ok, thanks for all the info!
I'll try to fix that when my new pentalobe bit arrives, but first my other iPhone where i accidently poked off a capacitor from, i guess, the logic board. -.-'
完成的
显示更多的1条评论
添加一条评论
Same thing to my phone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gertjan De Mulder 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 2,030
