跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
iPhone 3G lcd screen burned up after digitizer change. What happened?
Hey everybody i got a little problems here with my iphone lcd screen. And im hoping that some of you could help me with this...
Before i changed digitizer to my iPhone, my lcd screen was working well. Now after digitizer change i noticed black burns in the lcd screen. When i start up the phone over half of the screen has black burns and colourful stripes and in the other side i can barely see some graphics but in negative colour. The questions are:
What did i do wrong to cause this to the lcd screen?
and
Can this be fixed with a new lcd screen?
The screen looks like this (sorry for the crappy quality):
Thank you alot!
- Heikki
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Maybe you have endommaged the LCD flex cable when you replace it on the middle bezel assembly.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your quick answer. Umm but you mean i damaged the flex cable? Are you sure that its not just the lcd whats broken?
By the way there might be a chance that i accidently connected the wires to the lcd screen while the power was on. Not really good for the lcd right?
完成的
添加一条评论
Judging by the look of the screen the first thing I would replace would be the LCD. If that doesn't work you may have fried the mainboard but I doubt it will come to that.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your answer Peter! Yeah i just ordered new lcd screen and going to change it soon. Lets see what will happen. I hope the problem is not the mainboard...
完成的
添加一条评论
you should use the iPhone 3G lcd screen which is pre-assembled like this iPhone 3GS Replacement LCD Assembly I replace it with my iPhone 3G, no any problem..........
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the suggestion! but i already ordered a new lcd screen. Im gonna see whats going to happen. But good suggestion not an expensive price at all. Maybe i will order that if the lcd change doesnt help.
完成的
添加一条评论
添加你的答案
MrMouse 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,534
