跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Damaged battery after lcd replacement?
Yesterday I put in a new LCD replacement for my iPhone 4s 32 gb. The screen works great and everything else works as well after reassembly.. HOWEVER. My battery started to drain very rapidly once I powered on the phone. The phone was also warmer then usual.
It seems the battery only charges when plugged in and powered OFF! If it is on and plugged in, the battery will drain but at a slower pace.
Do you think I damaged my battery? or shotty reassembly that could have caused this problem? I was thinking I would try and replace the battery as a first step of trouble shooting.
Thanks in advance for any help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The first thing I would try is opening the phone and making sure that all of the connections are solid.
If all the connections inside the phone are still good, and you continue to have the same problem with the battery, then I'd recommend trying a new battery to see if that solves the problem. Good luck!
iPhone 4S Battery图片
产品
iPhone 4S Battery
$16.99
这个答案有帮助吗?
得分 2
添加一条评论
Make sure you have the Ground that is connected to the battery plugin with a screw. i had the same problem forgot to put the ground back in and battery drained rapidly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,731
