跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Sim Tray material short circuits?
Hi,
I have a few questions about the SIM tray and hope that you can answer it to me.
1. Which material is this tray?
2. Is there any coat in the SIM area?
3. Is the tray conductible?
Backround to the questions.
My Provider an't deliver Nano-SIMs this year. So i cut my SIM to the Nano size. But not the SIM is a Full Chip SIM with no plastic frame.
Now i have the question if i could have short circuits and the sim is not working?
In my iPhone 4 with Adapter the card works fine.
I hope you can help me and a few other users.
Thanks
André
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
the material is Ti-alloy, so it can be conductible. the sim card should be surrounded by plastic for fear of short curcuit
这个答案有帮助吗?
得分 1
添加一条评论
I had this conductive sim tray problem with my iPhone4.
Solution is to use a thin coating of nail polish between the overlapping areas between the sim and the tray.
The nail polish, (clear coat/nail hardener -best option) works as an insulato, blocking conduction between the sim and the carrier.
Avoid lathering the nail polish, only a very thin painted coat is necessary. Make sure any excess nail polish is scraped gently away from the sim or sim carier. Too much polish will prevent insertion of the sim carrier back into phone, any excess left can flake off and float around the inside off the phone and may cause problems.
Do not cover the portion of the sim card that needs to connect with the contacts inside the phone.
Likewise if you have one of the early iPhone4 that had the attenna problem, you can paint the aluminium edge with polish thus preventing your fingers shorting out the attenna/reducing signal. This means you can use your early iPhone4 without a bumber case. Later iPhone don't have this problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CSchnuffi5 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,996
