跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
iPhone thinks there is a sim, when there isn't?
Hi, I just repaired my iPhone screen, and I have done a few before with no trouble, but this time once I had put it back together, it is always searching for reception, but never finds it.
I tried restarting, taking the sim out etc but even without a sim, it doesn't say 'no sim' it still says searching.
Can anyone tell me what is going wrong and how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
Not totally a apple head here but i do know the iphone 4s has GSM (sim card) and CDMA cellular. i think this plays a role in this.
check your phone settings, And or a restore.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Set the date and time manually to the correct values and then restart your phone. Worked for me :)
这个答案有帮助吗?
得分 2
添加一条评论
I've got the same problem.. No one with a helpfull answer for this? Please
这个答案有帮助吗?
得分 1
1条评论:
Well, found a solution to this problem.
After changing three screens on iPhone 4S with iOS6. All three with this problem.
The solution I found: Insert the sim before you turn on the phone. Then connect the iPhone to the WiFi. Take the sim card out, and put if back in ;)
Hopefully this will resolve the problem.
完成的
添加一条评论
Your problem could come from 3 sources.
The first one is a software problem: just try to make restore with iTunes.
The second one could come from the sim reader commutator. If this commutator doesn't make contact, the iPhone will think that there is a sim in your slot. So you have to join them together. And after, you have to check if it's separates when you put your trap inside.
The third one is: you haven't properly plugged your antenna cable on the antenna connector.
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much for the second option, I know it's a very late reply, but this helped me SO much. After getting water in my iPhone 6, I thought the SIM slot had stopped working! Thank goodness for this otherwise I would've thought I needed to desolder and resolder things to fix it! It finally recognized when the SIM was and was not in the slot. Thank you so much!
完成的
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 6,783
